5 members (52Carl, GradyB, GRNHydra, Pre '68 Dave, DadsFirstPickup), 82 guests, and 1 robot.
Topics128,080
Posts1,055,944
Members48,430
#941012 05/05/2013 1:33 PM
I NEED YOUR HELP GENTS,I PURCHASED A 1965 CHEV SHORTBOX,12 BOLT WITH 5 LUG STUDS,IM SURE IT IS OUT OF TRUCK BY STABILIZER ROD ON TOP OF DIFF,CAN SOMEONE HELP ME FIND OUT WHAT ITS FROM AND RATIO,HA3 16 W ,AND C 2 5 IS ALL I CAN SEE FOR NUMBERS, IVE LOOKED ON INTERNET CANT FIND OUT ANYTHING ABOUT TRUCK 12 BOLT REAR ID,THANKS GUYS
shaker #941304 05/06/2013 6:10 PM
3B Offline
Hy shaker, try wire brushing the pinion at the front, there may be some numbers stamped into it. Failing that take the back cover off and clean the ring gear and look for some numbers there, hope that helps.
shaker #941307 05/06/2013 6:36 PM
ODSS Lawman
ODSS Lawman
I think most GM rear end housings have the numbers stamped on the passenger side of the housing.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
shaker #941311 05/06/2013 7:06 PM
I GOT C 2 5 FROM UNDER THE PUMPKIN,AND HA3 16W FROM PASSENGER SIDE AXLE HOUSING,WE WILL WAIT AND SEE IF SOMEONE KNOWS HOW TO READ THESE NUMBERS, THANKS GUYS
shaker #941317 05/06/2013 7:19 PM
This is a somewhat odd situation, as the codes that come up would not be for a 5 lug axle. The codes you provide from the axle tube break down like this; HA= '67-'69 1/2 ton w/3.73 ratio, 3= month built (May), 16= Date built, W= Warren assembly plant. It could be possible that the shafts have been swapped for 5 lug.
Bill Burmeister
shaker #941319 05/06/2013 7:29 PM
Are you talking about 12 bolts on the back cover? If so, it would be a Dana with the ring set built into the axle housing. If it has a torque arm, it probably came from something like an Oldsmobile with coil spring rear.
shaker #941432 05/07/2013 7:48 AM
YES 12 BOLT BACK COVER ,IT LOOKS JUST LIKE MY OTHER REAR IN 65 TRUCK,INTERESTING LONGBOX,ILL BET THEY WERE SWAPPED OUT,THANKS GUYS,
