10 members (JW51, Gdads51, artinva, Peggy M, VicZ, Ridgeback, RAC1812, Shaffer's1950, klhansen, 1 invisible),
122
0
Mod | | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | I NEED YOUR HELP GENTS,I PURCHASED A 1965 CHEV SHORTBOX,12 BOLT WITH 5 LUG STUDS,IM SURE IT IS OUT OF TRUCK BY STABILIZER ROD ON TOP OF DIFF,CAN SOMEONE HELP ME FIND OUT WHAT ITS FROM AND RATIO,HA3 16 W ,AND C 2 5 IS ALL I CAN SEE FOR NUMBERS, IVE LOOKED ON INTERNET CANT FIND OUT ANYTHING ABOUT TRUCK 12 BOLT REAR ID,THANKS GUYS | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy shaker, try wire brushing the pinion at the front, there may be some numbers stamped into it. Failing that take the back cover off and clean the ring gear and look for some numbers there, hope that helps. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I think most GM rear end housings have the numbers stamped on the passenger side of the housing.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | I GOT C 2 5 FROM UNDER THE PUMPKIN,AND HA3 16W FROM PASSENGER SIDE AXLE HOUSING,WE WILL WAIT AND SEE IF SOMEONE KNOWS HOW TO READ THESE NUMBERS, THANKS GUYS | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | This is a somewhat odd situation, as the codes that come up would not be for a 5 lug axle. The codes you provide from the axle tube break down like this; HA= '67-'69 1/2 ton w/3.73 ratio, 3= month built (May), 16= Date built, W= Warren assembly plant. It could be possible that the shafts have been swapped for 5 lug.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Are you talking about 12 bolts on the back cover? If so, it would be a Dana with the ring set built into the axle housing. If it has a torque arm, it probably came from something like an Oldsmobile with coil spring rear. | | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | YES 12 BOLT BACK COVER ,IT LOOKS JUST LIKE MY OTHER REAR IN 65 TRUCK,INTERESTING LONGBOX,ILL BET THEY WERE SWAPPED OUT,THANKS GUYS, | | |
