1 members (SlimSix),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94045 12/24/2005 6:25 PM | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | I'm re-wiring a 1949 chevy 1/2 ton pickup. The old wiring is so old (and painted over by the p.o.) that I can't see the colors of wires going to this part circled in orange (you can see a picture at: http://www.picturetrail.com/gallery/view?p=999&gid=8919034&uid=4216428&members=1 Based on the wiring schematic in the shop manual, I'm guessing that is part is the headlight dimmer switch, anyone know for sure before I wire to find out? Thanks | | |
#94046 12/24/2005 6:33 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well it appears to be in the right spot - if it sticks thru the floor by yer left foot, that must be it!
most of the time you can't see the wire color right by the part anyway on wiring so old, but you can frequently strip the outer covering on a bundle and find the color further back where it was protected
Bill | | |
#94047 12/24/2005 8:38 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Does it have a "finger" on it? If so it's your brakelight switch, Scott | | |
#94048 12/24/2005 9:37 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | DW,
I don't want to be a Christmas Grinch, but If you don't know what this part is just by looking at it, I sure hope you have a good helper when you start ripping wires out. Even seasoned veterans get confused when faced with a wire loom the size of a German sausage and instructions written in Cantonese! Good luck, this wasn't meant to be a "humbug".
Stuart | | |
#94049 12/24/2005 10:40 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it looks like this it's a dimmer switch. http://www.chevsofthe40s.com/browse.lasso?&search=dimmer%20switch&dept=truck&skip=2 A better pic would help. I zoomed the pic and still can't see the shape for sure. I may just be a bad angle but it looks too close to the steering column to be a dimmer.
#94050 12/24/2005 11:15 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Seems like the stop light switch is farther down & the dimmer switch is way over to the left side. How many wires connect to it? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#94051 12/24/2005 11:42 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | DW,
I got quite nervous..the Sharks wouldn't commit to the fact they were 100% sure it was the dimmer switch. If that was the case, in light of my previous post I would have to commit Hari Kari.
To avoid that unpleasant task, I hustled down to the shop where my naked cab rests on a dolly. I am now 99% sure the item you have circled in your picture is the dimmer switch.
If I am wrong, I will send you a case of Jack Daniels post paid, post haste! Feliz Navidad.
Stuart | | |
#94052 12/25/2005 4:41 AM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Easy Stuart,Rest easy,You got it,No need to be givin away the store. Now save somo that Gentleman Jack for me When I come visitin. By the way Merry Christmas | | |
#94053 12/25/2005 4:50 AM | Joined: Dec 2005 Posts: 1 Junior Member | | Junior Member Joined: Dec 2005 Posts: 1 |  Just wanted to say hi!! Stevesr is my dad! lol  | | |
#94054 12/25/2005 5:57 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Welcome daughter of stevesr, and Merry Christmas. "He who almost gave the store away" | | |
#94055 12/25/2005 6:29 AM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Hey Stuart At least I put her in a Chevy,Thankin the Lord She listens! Dads dont let 1st born daughters drive Ftur#s | | |
#94056 12/25/2005 11:19 PM | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | Thanks everyone, it is definitely the dimmer switch.
I thought the P.O. might have added a terminal relay of some type because I thought the dimmer would be lower on the firewall, but it is the dimmer. The stop switch is actually more towards the center of the firewall and the "fingers" on it are the bullet connectors (I had re-wired that switch previously when I wired a turn signal indicator to the rear lights).
I've seen lots of posts asking about putting in new wiring harnesses, I'll have to put in a post with pictures once I complete this. It's actually going pretty smoothly, the only difficult part is I can't "cheat" and use the "color coding" on the old wiring harness since its faded/painted over and the shop manual wiring schematic doesn't show the color coding anyway!
Merry Christmas to everyone! | | |
#94057 12/26/2005 3:39 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by DW: I've seen lots of posts asking about putting in new wiring harnesses, I'll have to put in a post with pictures once I complete this. It's actually going pretty smoothly, the only difficult part is I can't "cheat" and use the "color coding" on the old wiring harness since its faded/painted over and the shop manual wiring schematic doesn't show the color coding anyway!
Merry Christmas to everyone! Happy Ho Ho back at ya. If you go here you won't have to worry about the color coding, correct wires & connectors.: http://www.ynzyesterdaysparts.com/
#94058 12/28/2005 6:03 AM | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | Done! All the old wiring out, new wire harness installed and everything working. There's one page in the factory assembly manual that was invaluable in showing the wiring of the headlight switch, instrument clusters and ignition switch.
You should have seen the condition of the original wiring, there was more bare wire than you can imagine, and yet everything worked except the right high beam headlight!
Thanks everyone for responding. | | |
#94059 12/28/2005 6:07 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | DW, Your faster than a....? Well, your real fast. Will we get to see a picture of the finished product...just so we know you aren't pulling our leg. Congratulations. Stuart | | |
#94060 12/29/2005 6:23 AM | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | | | |
#94061 12/29/2005 6:35 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | DW, Definitely no leg pulling going on here! Great job...what's next? Its great to see a project started and finished in a single thread. Stuart | | |
