Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 49 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#939705 04/30/2013 5:50 AM
Does the seat fold on a 51 gmc 1/2 ton? do i have to take it out to work on the gas tank?
eyell #939712 04/30/2013 6:25 AM
On a standard cab there is no folding seat.
You'll have to remove the seat cushions and most likely the frame (depending on what work on the fuel tank has to be done).
eyell #939733 04/30/2013 8:27 AM
just took out my '53 GMC seat Sunday to pressure wash out rat & squirrel nests and...matter. Anyhow, the pipe tube looking frame and seat risers on the floor stay, you just grab the bottom seat cushion and pull straight out towards dash. For the backrest, you use a phillips to remove the 3 screws holding the c-shaped back frame peices to the large pipe-tube looking seat bracket, and pull it forward and out. Then you're left with an empty metal seat risers to the floor with the pipe-tube looking seat frame around it.
Moderated by  ndkid275, Phak1
