| | | Forums66 Topics128,019 Posts1,055,343 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | Does the seat fold on a 51 gmc 1/2 ton? do i have to take it out to work on the gas tank? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | On a standard cab there is no folding seat.
You'll have to remove the seat cushions and most likely the frame (depending on what work on the fuel tank has to be done).
| | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | just took out my '53 GMC seat Sunday to pressure wash out rat & squirrel nests and...matter. Anyhow, the pipe tube looking frame and seat risers on the floor stay, you just grab the bottom seat cushion and pull straight out towards dash. For the backrest, you use a phillips to remove the 3 screws holding the c-shaped back frame peices to the large pipe-tube looking seat bracket, and pull it forward and out. Then you're left with an empty metal seat risers to the floor with the pipe-tube looking seat frame around it. | | |
