5 members (KEVINSKI, cmayna, TexasJim50, Gdads51, 1955 1 Series), 49 guests, and 0 robots.
Topics128,080
Posts1,055,946
Members48,430
#93953 12/19/2005 4:10 AM
Junior Member
Junior Member
Hello;
My 1954 3100 has a condenser on the coil that I believe is to help keep static type noise out of the radio. I don't know which post of the coil it should connect to. I assume it connects to the ignition switch side and not the distributor side. Right? Also, will any condenser work? Thanks in advance for your advice.
Rich
#93954 12/19/2005 7:04 AM
IIRC, the only condenser is in the dizzy. You've probably got a resistor on your coil; it does go onto the ignition key side.
Do you have a 12v or a 6v system? If it's a 6v setup, then you don't actually need it. If it's 12v, you do. It will help your coil last longer.
#93955 12/19/2005 7:17 AM
there is an anti-static condenser on the coil for the radio, as well as one on the regulator, one on the generator, one in the hi-tension coil wire, and antistatic doobies in the front hubs - originally!!
original #'s:
ignition coil capacitor (No. 1929070) [+ term]
generator capacitor (No. 1911095)[arm term]
voltage regulator capacitor (No. 1917580) [batt term]
so it looks like, NO, any ol one won't do
prolly all unecessary if yer radio is A-1 or if you use a modern radio - they mostly got scrapped soon when any work was done on the part they're attached to
#93956 12/19/2005 11:18 PM
Riding in the Passing Lane
It hooks to the pos. side of the coil that goes to the switch or resister. An ign. cond. will not work.
1972 Chevy c10 Cheyenne Super
#93957 12/19/2005 11:57 PM
Junior Member
Junior Member
Hi to all;
Thanks for the good information. It is much appreciated. I will search out the correct part.
Rich
