1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | Hello folks....I plan a front disc upgrade on '47 1/2ton, using a non booster dual master cyclinder. I'd like to go to the local NAPA and buy the M/C and proportioning valve. Will any mid '70's chevy pickup cylinder work ? Any specific year etc ? Do you think it will have a built in residual valve ? Thanks for all your thoughts and comments. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | 72 up GM vehicles had disc brakes with a dual MC and a booster. Typically they also used a proportioning valve and had a built in residual valve. Disc brakes require more pedal pressure hence a booster would be the preferred set up. How a disc brake MC designed for use with a booster would perform without the booster would be speculative. Some aftermarket suppliers offer a kit with brackets, MC, & proportioning valve for use without a booster. I don't know what parts they use or how well they work. Fred
