5 members (Hawkman, Tom McGrath, 5 Window 9434, FAST55, dt235sd), 71 guests, and 0 robots.
Topics128,043
Posts1,055,615
#938884 04/26/2013 10:00 PM
Hello folks....I plan a front disc upgrade on '47 1/2ton, using a non booster dual master cyclinder. I'd like to go to the local NAPA and buy the M/C and proportioning valve. Will any mid '70's chevy pickup cylinder work ? Any specific year etc ? Do you think it will have a built in residual valve ? Thanks for all your thoughts and comments.
72 up GM vehicles had disc brakes with a dual MC and a booster. Typically they also used a proportioning valve and had a built in residual valve. Disc brakes require more pedal pressure hence a booster would be the preferred set up. How a disc brake MC designed for use with a booster would perform without the booster would be speculative. Some aftermarket suppliers offer a kit with brackets, MC, & proportioning valve for use without a booster. I don't know what parts they use or how well they work.
Fred
