5 members (Pre '68 Dave, Gdads51, FAST55, MickeyP, dt235sd), 89 guests, and 1 robot.
Topics128,049
Posts1,055,652
#93929 12/17/2005 7:24 PM
I just added this Rewiring Project Checklist to my site:
Click Here
It's a great list of all the things I needed to buy while I was doing mine ... and some things I wound up doing later on ... all compiled into a short checklist -- great for anyone who's getting ready to rewire their stovebolt.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
V
V Offline
Alan,
Thanks for your great site. I've used it quite a bit as a reference. I finished the wiring on my truck last week. I went with EZ wiring and some of the stuff from mad electrical to clean things up quite a bit.
You can check out some pics of the install:
http://homepage.mac.com/spider/truck/rewiring_project/rewiring_project.html
volcan
volcan96
Project Truck Website
I had fun looking at all your pictures, Volcan.
Congratulations on a successful EZ-Wire project!
I'm curious about your bed ... all I saw was plywood on the underside -- aren't there any cross-braces under the plywood? And what does it look like on the topside? Is it still just a sheet of plywood?
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
Great stuff.
I have a question, though. Are those relays voltage specific? (i.e. Can I use them on a 6v system, or do I need to find 6v relays?)
There are 6 volt relays and 12 volt relays ... here's a site that sells a 6 volt relay for $26:
see here
But I wouldn't pay that much ... you've got to be able to find a retailer that will do better than that.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
V
V Offline
Hi Alan.
As to your question about the bed. yes, it is just plywood with no cross braces (actually it has 1 cross brace that really isn't doing anything).
The topside is just a more weathered version of the bottom side.
This is one of the top priority items to fix after the major mechanical stuff is addressed.
volcan96
The bed of my truck also needs attention. There's a solid (one piece) sheet of 1/8" steel that's slid in over the old wood which appears to be original. All the cross braces and everything is still there ... I guess the previous owner just decided to cover it with steel.
Eventually, I plan on removing everything and doing something totally original with some hardwoods.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
