1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93879 12/13/2005 3:27 AM | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | My generator quit so I put an alternator on it, it doesn’t work however. What am I doing wrong? I hooked up the battery wire to the battery and the field wire to the positive post on the alternator. I hooked the idiot light wire up to a bulb. Any thoughts? | | |
#93880 12/13/2005 4:07 AM | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Sounds about right :confused: Did you take a reading with an volt meter at the alternator "Battery" post? Then at the battery positive terminal? When engine is running, both should read 13.5+ volts. If not, then the alternator maybe bad...that is if your alternator is an internal regulator type. But I'm sure you know that if the alternator is an external regulator type, then you'll need to connect a voltage regulator to it. [img] http://www.novaresource.org/alt/chargcircuit.gif[/img] | | |
#93881 12/13/2005 4:09 AM | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | That is the diagram I followed. Maybe it's the altinator. | | |
#93882 12/13/2005 5:43 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Um...does the altenator have an internal regulator? Was it bought new? Both my heep and my truck use external regulators. | | |
#93883 12/13/2005 1:50 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Make sure the idiot light is NOT grounded. | | |
#93884 12/13/2005 11:47 PM | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | It is an inturnally regulated altinator. Thanks everyone. | | |
