6 members (Ponchogl, IHPWR, Jon G, qside, Greg_H, 1 invisible), 73 guests, and 3 robots.
Topics128,136
Posts1,056,430
Members48,441
Hi All,
I'm working on re-assemblying a 1961 261.
There is a tapped hole in the middle of the third main bearing cap. It doesn't go all the way through. I don't remember anything being in there and I can't find a picture in the manual. I took a picture of the hole, but I can't figure out how to post it. I don't remember if anything went there.
Thanks for your help.
Joe
Third from front or rear?
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Doin' the same to my 61-261. Have the same tapped hole but don't remember taking anything apart from it. Have seen pics of the lower engine assy, but nothing in the hole. Good luck on your buildup
Front.
Thanks. I'm pretty sure there was nothing in it.
Up to 1954(55 1st truck)the oil pick-up screen bolted to #3 main cap.
I have never seen anything newer with something bolted to that cap.
My Blog
I was thinking the same thing, oil pump pickup tube
1953 Chevy Two-Ton
