| | | Forums66 Topics128,049 Posts1,055,747 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | While working on a misfire on my 55.2's 235 I pulled the plugs and scoped the cylinders. I was pleased to see a beautiful cross hatch on the walls and fresh pistons marked .30+ along with shiney valves and a clean head so the P/O was at least correct about that. The miss was just incorrectly adjusted valves and it purrs like a kitten now and huge difference in power. So what would my displacement be if its been bored 30 over. I can find specs on about every engine out there but not a 235 | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | I calculate displacement bythe formula :
bore x bore x .7854 x stroke x number of cylinders .
figure area of cylinder ( bore x bore x .7854 ), then cylinder volume in cubic inches (area x stroke), this multiplyed by number of cylinders gives the engine displacement.
there is an alternate formula to calculate area of cylinder (circle).
Bob Taylor
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . . So what would my displacement be if its been bored 30 over. I can find specs on about every engine out there but not a 235 What specs do you need? A Shop Manual and a calculator? Use the standard dimensions first. Make sure it gives 235.5 (approximately). Add your overbore to the bore. My guess is that you mean 0.030" over bore? 239.4 cubic inches? Double-check me - I also shift decimal points and miss digits. | | |
