| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | I have a 235 with single carb, Fenton dual exhaust and Mallory ignition. I want to install dual Carter-Weber carbs. The Mallory does not have a vacuum advance. Considering replacing the Mallory ignition with HEI ignition. My original distributor is long gone. Was told the HEI will respond better as a daily driver. Looking for some input on the distributor ignition.
| | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I recently put an hei distributor on my 250. I had an awful intermittent miss and was thinking that I made a mistake buying a $65.00 Chinese distributor off ebay. I finally found a loose wire on the distributor (my own fault). Now the motor runs better than it has since I got it. The points kept fouling on the old distributor is why I changed it. I am not sure if it would be an upgrade for your Mallory or not.I was replacing a wore out distributor.
Gene 1959 Apache
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Larry, i ran an old dual point Mallory for several years, should have swaped it out for HEI sooner! Got one From Tom @ Stovebolt, used a set of NAPA Blue max wires for a later Ford 300 six. It was at least the 2nd best upgrade I've done for driveablility, right up there w/ T5 swap. '60 C10 235 / T5 & 3.56 spicer power loc
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | See the TECH TIPS here on the 'Bolt for a good "How-To" on using an HEI on a 235 or 261. Remember to run a 10ga power lead from an always on switched power source.
I have bought HEIs on ebay and on the inside of the casting they say "Holden" which is GM in Australia. There may be some Chinese ones there, but I have never gotten one. All the "ebay" ones seem to have to much vacuum advance. I have had to replace the vacuum can with a 10 degree can from a V-8 "High Performance Kit" from the flaps. ALL the HP parts that fit the V-8 version work on the L6 version except the cap and shaft! Have fun, guys!
Best wishes,
Les | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | Talked with Tom Langdon yesterday. The carbs and HEI distributor are ordered. | | |
