5 members (52Carl, Mike B, 1955 1 Series, Otto Skorzeny, dt235sd), 85 guests, and 0 robots.
Topics128,155
Posts1,056,868
Members48,456
#937052 04/20/2013 7:28 AM
b10
Offline
When trucks came of the line new and the color of the truck was blue what did they paint the rims ?Same color or others. Sanding my rims to paint, found multi colors in layers,Black,White,light blue,and a [censored] yellow.Thanks
b10,
The 3100 wheels in many Advance-Design years (47-55) were black, except for Suburban Carryall (which had body-colored wheels). Maybe someone has documentation specifically for 1951?
In 54/55, the standard-cab 3100 wheels were black, except for some of the deluxe and/or two-tone exterior options (which might have had body-colored wheels).
GMC wheel colors were often (always?) different from the body color for New Design years (47-55).
b10
Offline
You guys are great with fast answers and black its going to be. As always THANKS!
How do you fellows do the pin striping on the wheels? Mask off lines, a pinstripping tool or pinstriping tape?
- Lonnie
My '54 3104
Spin the wheel on the spindle and touch the tip of a fine/thin paint brush (or pinstriping "tool") to the spinning wheel (before the tire is mounted).
Look at how the "tool" is being used on the yellow wheel; but, no help for the inner stripe?
I see a common denominator in these posts. You need at least 3 alcoholic drinks in you before your hand becomes steady enough to paint the stripes. I had forgotten about there also being a pinstripe on the cab beltline also.....
I did 2 of my 15" rims by taping with masking tape after using a large compass to draw in lines for the pinstripes. They wasn't too bad, but I did have to go back and touch up a few places where the paint creaped back under the tape.....
Biggest problem with taping is if the rim has some pits in the metal....
Thanks John
My imagination or does the inner most and outer most pinstripe on the wheels look to be thicker than the one in between??
Here are three 3/4" (supposedly) pinstripes.
In Cosmo's photo the widths might look different due to downward curve in the center of the wheel (and a straight-on photo of the wheel)?
