Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Frank50, 55shaker, 1955 1 Series), 48 guests, and 2 robots.
Topics128,006
Posts1,055,272
Members48,418
#936722 04/18/2013 7:02 PM
what makes the right side of my headlight and parking light brighter than left side, bad ground?
696969 #936724 04/18/2013 7:07 PM
Probably.
696969 #936826 04/19/2013 8:36 AM
Ex Hall Monitor
Ex Hall Monitor
You don't say what year vehicle. If it's old enough to have separate bulbs in a reflector it could be tarnish on the reflector on one side. I have that issue with my '38 to a minor extent. In my case it isn't bad enough to require re-silvering.
696969 #936883 04/19/2013 2:01 PM
Sir Searchalot
Sir Searchalot
As said , need to know year??? If it is two separate lights (headlight and parking) then they have separate bulbs, probably separate wiring and ground. Their common connection would be the switch possibly. Or any terminal block they both share. If both have a wire from the bulb housing to the same ground, then that is probably the problem. If they have different ground spots, probably not ground problem. At any rate, play around with the ground while lights are on, try to establish another ground with a test wire. Check switch connection. Check any other common connections. A dim light does usually mean ground, you are correct.
696969 #936903 04/19/2013 3:20 PM
it is a 48 gmc 1/2 ton...all new wiring, lights new, everything electrical is new, back to drawing board, thanks guys...
696969 #936920 04/19/2013 4:59 PM
Ex Hall Monitor
Ex Hall Monitor
Turn your lights on with the bulbs disconnected. Use your multi-meter to determine the voltage at each socket. If they don't match side to side you have some searching to do.
696969 #937008 04/19/2013 11:10 PM
It may be the old rusty inner fender bolts aren't making a good ground. Sounds illogical but it wouldn't hurt to run a jumper cable from the fender to the frame and see if it affects the lights.
696969 #937087 04/20/2013 9:33 AM
With the 48 1 ton I had years ago it was a bad groun on dim side. New ground wire and it brightened right up.
696969 #937106 04/20/2013 10:54 AM
hi guys, found problem, couple things, first, ground wire came unhook, second, had couple wires in wrong spots, everything working great...thanks guys
696969 #939463 04/29/2013 9:15 AM
yeah, when you turn on the lights and the toilet flushes inside the house, there's a problem.......
glad you got it sorted out.
696969 #939550 04/29/2013 4:17 PM
Ex Hall Monitor
Ex Hall Monitor
Originally Posted by 696969
.....second, had couple wires in wrong spots......
Been there, done that. At least you didn't let the smoke out.
