2 members (2-Ton, MikeE), 86 guests, and 3 robots.
Topics128,266
Posts1,058,385
Members48,485
#936747 04/18/2013 8:06 PM
I have a chance to purchase some 19.5 tires and rims for $50 each. I know your not suppose to mix radials with bias ply, But don't fully understand why. It be would just the two 19.5's for steers, and the bias on the rear duelly. I just figure on such a low speed truck it wont matter mixing radials with bias. Thanks, Mike
Back in the '60 when radials were just becoming accepted in the US (used in Europe for years before)the rule was - if you mixed radials and bias, radials on the front first.
Radials have much better turning traction and over steer was much easier to control than under steer.
You have it backwards, radials go on the rear, not the front, if mixing with bias, per the DOT.
Bill Burmeister
I ran 19.5 radials on the rear and bias on the front of my 52 1 ton with no troubles at all
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #936868 04/19/2013 12:56 PM
Griggs & Longbox have it correct. If you must mix, bias on front, radial on rear.
Radials on the front only can make it very easy for the rear end to try to pass the front during braking.
I know, never going to drive that fast or brake that hard but ---- it only takes once!
BC
1960 C60 pasture art
When we first made the switch from bias to radials about 35 years ago, we still ran bias on the steering axle and radials on the drive and trailers. Eventually we started putting radial on the steering axle also after we got power steering on all of our tractors. Bias tires on the steering axle held the road better without power steering than radials.
