| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | I have a chance to purchase some 19.5 tires and rims for $50 each. I know your not suppose to mix radials with bias ply, But don't fully understand why. It be would just the two 19.5's for steers, and the bias on the rear duelly. I just figure on such a low speed truck it wont matter mixing radials with bias. Thanks, Mike | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Back in the '60 when radials were just becoming accepted in the US (used in Europe for years before)the rule was - if you mixed radials and bias, radials on the front first. Radials have much better turning traction and over steer was much easier to control than under steer. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You have it backwards, radials go on the rear, not the front, if mixing with bias, per the DOT.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I ran 19.5 radials on the rear and bias on the front of my 52 1 ton with no troubles at all | | | | | Joined: Sep 2011 Posts: 1,468 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,468 | Griggs & Longbox have it correct. If you must mix, bias on front, radial on rear. Radials on the front only can make it very easy for the rear end to try to pass the front during braking. I know, never going to drive that fast or brake that hard but ---- it only takes once!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | When we first made the switch from bias to radials about 35 years ago, we still ran bias on the steering axle and radials on the drive and trailers. Eventually we started putting radial on the steering axle also after we got power steering on all of our tractors. Bias tires on the steering axle held the road better without power steering than radials. | | |
