11 members (Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible),
98
Mod | | | Forums66 Topics128,169 Posts1,057,037 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93611 11/28/2005 4:24 PM | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | I'm trying to remove the wiring harness from my '66 cab so I can have the cab blasted. I can't figure out how to get it out; the firewall area specifically. How do you get the firewall penetrations to come out?
Thanks in advance! | | |
#93612 11/28/2005 7:08 PM | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | | | |
#93613 11/28/2005 7:14 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Push the connector through to the engine side of the firewall. Then pull the rubber grommets into the cab side using a pair of needlenose pliers. Old grommets will probably self destruct, you can get new ones. Then pull the connector back through. | | |
#93614 11/28/2005 7:30 PM | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | Thanks, Vaughn; That's how I thought they came out. How do you push them through? I used a broom handle and a hammer; they wouldn't budge. | | |
#93615 11/28/2005 8:27 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | The rubber has hardened to a point that it won't deflect anymore. The only solution is rip out pieces of it with the needlenose pliers until you can get the connector out. You can't heat them, it will melt the connectors. | | |
#93616 11/28/2005 8:50 PM | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | Thanks for the help, Vaughn! | | |
