Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Shaffer's1950, Hanks custodian, Wally / Montana), 106 guests, and 7 robots.
Topics128,283
Posts1,058,519
Members48,490
What are the best options for swapping out a smaller steering wheel in a stock 53 3100? I would like the cab to look as stock as possible. Is it possible to modify a 54 steering wheel to use with the 53 steering shaft?
DAve
I have seen a custom AD truck with a smaller diameter stock steering wheel.
AFAIK someone is making them now,not sure who but if I find out i'll let you know.
I've no doubt it will be expensive.....! frown
More pix on Flickr.
'53 and '54 use the same diameter steering wheel, 18". The steering wheels mounting is the same at least from '47-'93, possibly later (I haven't taken too many airbag style steering wheels off).
Are you planning on installing power steering? A smaller steering wheel will increase steering effort.
Bill Burmeister
I second the opinion on the increased steering effort of a smaller steering wheel. I would be looking for a larger than stock wheel myself if my belly wasn't so big. Maybe I need to work on my big-assed belly.
Wait a minute...are you saying you have a big [censored] and A BIG BELLY?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Redryder pix
My Hotrod
I think I shared way too much personal information.
Thanks for your ideas. I need to get a tape and measure some of these steering wheels. I may be more comfortable if I can reduce the thickness of the seat back so I can sit further back an inch or so. Steering effort on my truck is very light--I'll find a 54 steering wheel and compare the diameter with mine.
Dave
Why didn't they build them that way to begin with??? Beautiful truck...even if it does look like a 56 Ford.
Dave
Moderated by  ndkid275, Phak1
