3 members (MRMEROTH11, WICruiser, wilbur53), 111 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#934337 04/09/2013 6:04 PM
On my brother-in laws 1954 p/u the steering is scary loose. We tried the adjustments but not enough improvement. Are we at rebuild point? Hard to do? recommend sending out? Thanks Scott
chevymgb #934340 04/09/2013 6:33 PM
I have been reading through past posts on steering. all other components are new and tight. excessive play in wheel. We were thinking box is wore beyond further adjustment?
chevymgb #934343 04/09/2013 6:48 PM
How did you make the adjustments? If nothing is broken inside
the steering box you should be able to adjust the sector to the
point that it literally locks up the box even if it is worn.
But you are correct in your concern for safety, faulty steering
is nothing to mess with. If you feel uncomfortable with your
efforts then it would be a very good move to seek a real mechanics advice.
Denny G
Denny G
Sandwich, IL
The adjustment screw is just about all the way in, steering is stiff but it has a lot of play at the steering wheel
chevymgb #934389 04/09/2013 8:27 PM
Did you go through the adjustment procedures in the Shop Manual? What measurement tool did you use for the worm bearing adjustment?
tclederman #934434 04/09/2013 10:06 PM
I adjusted about a quarter turn of play out of my steering. Easy to do. I followed the Shop Manual.
> Shop Manual - Steering Gear Adjustments
You must disconnect the pitman arm before making the adjustments. Advance Auto Parts, and probably other FLAPS, will loan a puller.
I used a digital fish scale to check the pull on the steering wheel as described in the Shop Manual. I'm not real sure that a scale is even needed.
> Digital Fish Scale
If all else fails, instructions for rebuilding the box are in the Shop Manual and in GM Steering Manuals. Plus, do a search on Stovebolt for real world advice.
> Shop Manual - Steering Gear Major Service
> Overhauling Truck Steering Gears
Many 'Bolters recommend refilling the box with John Deere Cornhead grease. You can find more info in a Stovebolt search.
Good luck,
- Lonnie
- Lonnie
My '54 3104
chevymgb #934507 04/10/2013 8:42 AM
Riding in the Passing Lane
If all else is good nothing will help it drive better then pulling the steering gear out & rebuilding it. There is not that much to them.
1972 Chevy c10 Cheyenne Super
chevymgb #934526 04/10/2013 10:09 AM
The teeth on the sector can wear and no amount of adjusting will fix it. Sounds like you are at that point. It will need to come off for a look or replacement.
Joe
Joe H #934632 04/10/2013 5:08 PM
Thanks guys, He assured me we followed manual, with the exception of the scale. So, it maybe time to remove it and see.
chevymgb #934645 04/10/2013 5:54 PM
Something not mentioned that might be worth checking into in addition, the preload on the tie rod ends, if it still has the factory style ends. Even if they feel "tight", they may not have enough preload on them, which can give a loose steering feel. I found that out the hard way myself, and chased it by adjusting the box. Once the tie rod was adjusted to the proper preload, the steering was fine.
Bill Burmeister
chevymgb #934738 04/10/2013 10:56 PM
A good/correct adjustment was not carried out.
I do agree. We removed box and disasembled. Ordered rebuild kit from Jim Carter. After seeing the guts, I now understand the importance of the pittman arm removal. The worm gear parts do not appear to be too worn out, so we may be sucessful. Also have a scale to do a proper adjustment. Much better understanding of how it adjusts now.
chevymgb #937325 04/21/2013 10:42 AM
Good job, chevymgb
Be sure to post a post-adjustment driving report.
chevymgb #937462 04/21/2013 7:22 PM
Thanks everyone. I will let you know the results.
On the bench the gear "fingers?" in the box appear to have enough adjustment left. Worm drive on shaft looks good. Bearings & bushing are most diffenatly in need of replacement.
Thanks again Scott
chevymgb #937473 04/21/2013 8:28 PM
Mine was loose and really scary sloppy when I first bought it...a 49. Turned out that pretty much all the front end components were badly worn and missing the bushings. King pins loose and steering box held on my one thread of the nut. I chose to put in a whole new front clip but that was expensive. For me, safety way out weighed originality. I'll also go with radials which will, hopefully, make it drive like new and, most importantly, be safe.
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
