5 members (J Lucas, Hanks custodian, Bill Hanlon, HelmutVonSchet, klhansen), 132 guests, and 2 robots.
Topics128,193
Posts1,057,255
Members48,466
Hello Everyone,
I was looking for information on what slip yoke and drive shaft was used when a T5 trans conversion was done. This will also include the size of u-joints.
Bread
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
Riding in the Passing Lane
Use your original drive shaft. Get a yoke from practically any 68 up GM using a 3 speed or automatic trans. except TH400. Contact a drive shaft shop & give them the dementions. They will modify yours to fit & install the correct u-joint.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret,
Thank you for the reply and advice. I parted with the closed drive shaft and rear axle w/leaf springs. I was looking at getting an S10 drives shaft from the salvage yard and have it cut to length. It seems that all the salvage yards here are tapped out of S-10s. I do not know what kind of slip yoke and u-joints needed to completed the connection. I have looked at some venders for a borg warner compatible slip yoke but there are many to chose from.
Thanks for the help,
Bread
I used the drive shaft from a 78 oldsmobile cutlass, had to have it cut to fit
Hoozat,
Thanks for the chime.
Where did you get the slip yoke?
Bread
got it with the transmission, the u joints are pretty much all the same with the cars and small trucks
I have the s-10 rear and the s-10 t-5 tranny in my truck with the original 216 motor and it runs just fine
I used an 90's Chevy Astro van driveshaft when I did the T5 conversion on my 54 3100. I didnt have to cut or modify the driveshaft. The slip yoke fit the T5, all I needed was a combination ujoint to mate it to the 62 C10 diff that I used.
Gents,
Thank you for the advice, I really appreciate it.
Bread
