| | | Forums66 Topics128,097 Posts1,056,495 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Hello Everyone, I was looking for information on what slip yoke and drive shaft was used when a T5 trans conversion was done. This will also include the size of u-joints.
Thanks, Bread . | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Use your original drive shaft. Get a yoke from practically any 68 up GM using a 3 speed or automatic trans. except TH400. Contact a drive shaft shop & give them the dementions. They will modify yours to fit & install the correct u-joint. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Wrenchbender Ret, Thank you for the reply and advice. I parted with the closed drive shaft and rear axle w/leaf springs. I was looking at getting an S10 drives shaft from the salvage yard and have it cut to length. It seems that all the salvage yards here are tapped out of S-10s. I do not know what kind of slip yoke and u-joints needed to completed the connection. I have looked at some venders for a borg warner compatible slip yoke but there are many to chose from. Thanks for the help, Bread .
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I used the drive shaft from a 78 oldsmobile cutlass, had to have it cut to fit | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Hoozat, Thanks for the chime. Where did you get the slip yoke?
Bread . | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | got it with the transmission, the u joints are pretty much all the same with the cars and small trucks
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I have the s-10 rear and the s-10 t-5 tranny in my truck with the original 216 motor and it runs just fine | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | I used an 90's Chevy Astro van driveshaft when I did the T5 conversion on my 54 3100. I didnt have to cut or modify the driveshaft. The slip yoke fit the T5, all I needed was a combination ujoint to mate it to the 62 C10 diff that I used. | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Gents, Thank you for the advice, I really appreciate it.
Bread . | | |
