| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | I've ordered a headliner kit for my 1949 chevy cab and it appears that there might have been a mid year change in the design. Does anyone know for sure if the 49 had a later 1/2 year change in size? I noticed they are sold as 47 to 49 and also 49 to 53? | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I belive If your center headliner bar is fixed to the roof it is a early '49. If it floats and is crimped to the head liner it is a later model. I'm sure some one will correct me if I'm wrong. Cleon | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Cleon is correct, lots of mid-year 49 changes. Some of the vendors describe these pieces better than others as well. This change is best described as a fixed rib (2-piece design) for 1947-mid 49. Or floating rib (single piece design for late 49-55 1st Series. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Late 1949 (as posted above):
• New-style cab windlace fits in metal track around door opening.
• Headliner center bow is now "floating type", no longer screwed to roof of cab.
• Hood side emblem says CHEVROLET, no longer says THRIFTMASTER or LOADMASTER.
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Thanks guys for pointing out these differences! It sure makes good sense as to why I couldn't properly install the one I have now. I have just ordered a replacement headliner, the none floating type, earlier 49 cab. | | |
