2 members (Peggy M, 1 invisible), 92 guests, and 2 robots.
Topics128,072
Posts1,055,904
Members48,429
Asking for a buddy's truck. I tried to search the forums but didn't find anything specifically to this issue. Is the headlight ring on an AD truck held on with a screw at the bottom or does it just pop on and is spring held? If anyone knows or can provide a link, instal;/removal instructions, I would appreciate it. Thanks!
1946 Chevrolet 1/2-ton
More pix on Photobucket
The bucket should have a tab to accept a screw that hold the trim ring
You can see the tab in this pic
...pic...
About the 1:00 o'clock position in that pic.
Installed it will be at the bottom
Often times the tab is broken/ missing
Thanks Dads50. I was under the impression no screw was used on the trim ring but I guess I was wrong.
...click...
One of my headlamp rings is missing the tab for the screw, haven't lost it yet.
But I do have a replacement bucket to change it out.
You can purchase those tabs that the headlight rim is screwd to....I think. I'm almost sure I have a new I bought somewhere out in the shop.
Big Tee, there are some springs on the back of the headlight rim and the one at the top of the headlight rim fits down into a slot on the top of the headlight bucket........ I'm sure you know this but just in case you didn't. Good luck.
Here you go. Bottom of the page. $4.50 each
http://www.oldchevytrucks.com/cart/index.asp?cat2=9929&path=1947+%2D+Early+1955+Truck+Parts%2FLighting%2FHeadlights
