1 members (RLB),
92
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Well, today was the day to start up the new 207 engine,warm it up and get it hot and set the cam...then I stopped it to check oil level first..noticed milky looking oil on dipstick..bad news..water is leaking into the engine somewhere!! Big Setback, drained all the creamy oil.. we'll pressure test radiator ( GMC rad,was was sent to me by a friend)..it was checked also. Rebuild guy won;t want to hear this news...Engine block and head was Dyna fashed...what could cause this? We will turn engine today with starter, remove the plugs to see if water spurts out of any...any other suggestions?.about ready to give up! mtvoices... | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mtvoices, sorry about your problems, I have never heard/read the term "Dyna fashed", is that another name for Magnafluxing? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Was the block and head resurfaced? Were they magnafluxed? It is possible you used the wrong head gasket.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You may want to try and retorque the head. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | They were Magnafluxed..on the bill stated. I talk to this guy monday, but I have the feeling he will try to get out of taking back engine to check it out..I hope I'm wrong..I supplied the gaskets, and they were very good ones..150.00 for the entire set. I'm just sick at this whole project coming down to a pinhole or a crack that he might have missed. Milky oil all over the grage floor..uggh! Bruce D. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Well w never even got that engine warmed up enough..but I can asked about retorquing...It may be a pinhole or a smalle tiny crack....who knows..I know the water in the radiator could not get into the oil pan..but it did some way...it all has to come out of this beautiful rig..Bruce | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Sorry My mistake..not Dyna..manafuxed.. head too full of ideas..ha! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I think I'd run my down leak down tests before taking it back so I knew what is what... And then compare that to what the mech says...
Just to check how much I trust his knowledge and honesty.
