5 members (5 Window 9434, Jon G, John Dlugos, jmoore, moparguy), 96 guests, and 4 robots.
Topics128,120
Posts1,056,325
Members48,439
#933624 04/07/2013 9:29 AM
Well, today was the day to start up the new 207 engine,warm it up and get it hot and set the cam...then I stopped it to check oil level first..noticed milky looking oil on dipstick..bad news..water is leaking into the engine somewhere!! Big Setback, drained all the creamy oil.. we'll pressure test radiator ( GMC rad,was was sent to me by a friend)..it was checked also. Rebuild guy won;t want to hear this news...Engine block and head was Dyna fashed...what could cause this? We will turn engine today with starter, remove the plugs to see if water spurts out of any...any other suggestions?.about ready to give up! mtvoices...
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
3B Offline
Hy mtvoices, sorry about your problems, I have never heard/read the term "Dyna fashed", is that another name for Magnafluxing?
Was the block and head resurfaced?
Were they magnafluxed?
It is possible you used the wrong head gasket.
My Blog
You may want to try and retorque the head.
They were Magnafluxed..on the bill stated. I talk to this guy monday, but I have the feeling he will try to get out of taking back engine to check it out..I hope I'm wrong..I supplied the gaskets, and they were very good ones..150.00 for the entire set. I'm just sick at this whole project coming down to a pinhole or a crack that he might have missed. Milky oil all over the grage floor..uggh! Bruce D.
More pix on Flickr
Well w never even got that engine warmed up enough..but I can asked about retorquing...It may be a pinhole or a smalle tiny crack....who knows..I know the water in the radiator could not get into the oil pan..but it did some way...it all has to come out of this beautiful rig..Bruce
More pix on Flickr
Sorry My mistake..not Dyna..manafuxed.. head too full of ideas..ha!
More pix on Flickr
I think I'd run my down leak down tests before taking it back so I knew what is what... And then compare that to what the mech says...
Just to check how much I trust his knowledge and honesty.
Give me ambiguity
or give me something else
