Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Guitplayer, Otto Skorzeny), 127 guests, and 4 robots.
Topics128,290
Posts1,058,566
Members48,492
got my nos ignition switch, as my luck has it , having trouble (installing) getting to it,, first, it has those clutch-head or similar type , I hate those things, does anyone know what the correct size of driver I could get for these,, appear to be org........thanks,Fred
Redryder pix
My Hotrod
I
I Offline
That is one of the things that amazed me about my '48... Didn't find one single clutch head screw.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
Inky05,
'48 was the only year they didn't use that style
screw. There was an embargo on goods from India and they wouldn't let any ships into the country. GM, for lack of a better phrase "didn't get screwed".
Joker, go down to Home Depot and buy a set of clutch heads, then you will always have the proper size..do it before another embargo happens!
Stuart
sounds like a good idea,,, these may not be clutch head , could these be torks or what-ever,,,clutch head and torks are 2 different things, arent they?
Redryder pix
My Hotrod
CLUTCH vs TORX [towards the bottom] - should be easily able to see the difference
so clutch it is,, thanks for taking the time to link and explain,, with this link I can screw anything that might pop up.......................thanks,,Fred
Redryder pix
My Hotrod
Fred,
When I worked at Home Depot we didn't have clutch head screw drivers.
I got a set of clutch head "bits" that you can put in a drill or a screwdriver handle at Elliot's Hardware on Motor street in Dallas. They also had them individually.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
Johnny, thanks for the tip,, good to hear from you..regards............Fred
Redryder pix
My Hotrod
My local hardware store, which is a chain, carries the clutch head screwdrivers, both individually and sets.
Word hard, play harder, enjoy life!
