1 members (1 invisible),
156
Mod | | | Forums66 Topics128,290 Posts1,058,562 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93353 11/03/2005 3:39 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | got my nos ignition switch, as my luck has it , having trouble (installing) getting to it,, first, it has those clutch-head or similar type , I hate those things, does anyone know what the correct size of driver I could get for these,, appear to be org........thanks,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#93354 11/03/2005 9:14 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | That is one of the things that amazed me about my '48... Didn't find one single clutch head screw. | | |
#93355 11/03/2005 9:55 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Inky05,
'48 was the only year they didn't use that style screw. There was an embargo on goods from India and they wouldn't let any ships into the country. GM, for lack of a better phrase "didn't get screwed".
Joker, go down to Home Depot and buy a set of clutch heads, then you will always have the proper size..do it before another embargo happens!
Stuart | | |
#93356 11/03/2005 11:44 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | sounds like a good idea,,, these may not be clutch head , could these be torks or what-ever,,,clutch head and torks are 2 different things, arent they? Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#93357 11/04/2005 2:12 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | CLUTCH vs TORX [towards the bottom] - should be easily able to see the difference Bill | | |
#93358 11/04/2005 2:59 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | so clutch it is,, thanks for taking the time to link and explain,, with this link I can screw anything that might pop up.......................thanks,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#93359 11/10/2005 2:43 AM | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | Fred, When I worked at Home Depot we didn't have clutch head screw drivers. I got a set of clutch head "bits" that you can put in a drill or a screwdriver handle at Elliot's Hardware on Motor street in Dallas. They also had them individually.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#93360 11/10/2005 3:07 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Johnny, thanks for the tip,, good to hear from you..regards............Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#93361 11/10/2005 3:51 PM | Joined: Jul 2005 Posts: 135 Member | | Member Joined: Jul 2005 Posts: 135 | My local hardware store, which is a chain, carries the clutch head screwdrivers, both individually and sets.
Word hard, play harder, enjoy life!
