1 members (baldeagle), 29 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#932519 04/02/2013 9:31 PM
My new points didn't come with cam lube for the rubbing block on the points. So what would be a good grease to use?
TIA.
Brian
Brian
1955.2 3100 Truck
55shaker #932549 04/02/2013 10:53 PM
Distrubitor Gease
/\ /\ Click it...
Ted
My ride but looking for a Deco Bolt for the wife.
55shaker #932582 04/03/2013 3:36 AM
CarQuest in Princeton Brian. This is a little more reasonable
and a tube will last you as long as you got left in the garage.
Distributor Cam Grease Part Number: 52-8600 Price: $5.87
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
55shaker #932800 04/03/2013 8:59 PM
Toolbox and Denny, thank you.
Brian
1955.2 3100 Truck
55shaker #932886 04/04/2013 8:39 AM
Ex Hall Monitor
Ex Hall Monitor
I use white lithium assembly lube. I used it the first time because I didn't want to drive into town and I have the assembly lube on the shelf. It has worked great since and like Denny said a little bit goes a long way.
Tiny #932893 04/04/2013 9:37 AM
Is that where the Shop Manual ('54) says to use petroleum jelly?
> "DISTRIBUTOR" Bottom, left column
- Lonnie
- Lonnie
My '54 3104
55shaker #932999 04/04/2013 6:38 PM
Nice catch Lonnie, you must spend all your spare time reading
the small print.
Who doesn't have a jar of Vaseline® Petroleum Jelly, aka Rod
Wax, sitting idle in the back of the medicine cabinet. I think
I've probably got a half dozen old jars in the top of the tool
boxes and on shelves in the shop.
Ya taint gonna get off any cheaper than that.
DG
Denny G
Sandwich, IL
55shaker #933348 04/06/2013 12:02 AM
Mr. Graham.....rod wax!! You should be locked up Mr. grin
Stuart
55shaker #933350 04/06/2013 12:17 AM
atomarc, welcome back. I hope you are well.
I truly had thought that Denny was referring to a fishing rod.
Thank you for clarifying that, as you often did on many topics in the past.
atomarc #933392 04/06/2013 9:45 AM
Ex Hall Monitor
Ex Hall Monitor
Indeed! Welcome back Stuart! We've missed you and your deep well of knowledge.
55shaker #933468 04/06/2013 5:46 PM
Tim & Tiny,
Thanks...seems like you become part of a family when you are infected with 'Bolt-itus' and you have to come home every once in a while to see what goes on.
In my lurking I see that Tim has graduated to a big bolt...that sounds fun...and Tiny still has 'Sweetie', a truly sweet ride.
Stuart
55shaker #933528 04/06/2013 9:40 PM
Oh you youngsters, I gotta teach you everything:
"The raw material for petroleum jelly was discovered in 1859 in Titusville, Pennsylvania, United States, on some of the country's first oil rigs. Workers disliked the paraffin-like material forming on rigs because it caused them to malfunction, but they used it on cuts and burns because it hastened healing."
"Robert Chesebrough took the unrefined black "rod wax", as the drillers called it, back to his laboratory to refine it and explore potential uses. Chesebrough discovered that by distilling the lighter, thinner oil products from the rod wax, he could create a light-colored gel. Chesebrough patented the process of making petroleum jelly by U.S. Patent 127,568 in 1872."
Denny G
Denny G
Sandwich, IL
55shaker #933544 04/06/2013 10:25 PM
That Wikipedia entry is not explicit about the rod where the wax accumulated - it was the oil pump's main rotating rod.
Atomarc is the one with the double-entendre mind? But, many of us bought into his notion.
55shaker #933665 04/07/2013 11:26 AM
And you wonder why I feel the need to write short stories in my
replies instead of one liners?
Some years back I watched a Ken Burns documentary where they
portrayed what life was like back in the early oil fields.
So that's where I got the term from and ever since then I've
refered to Petroleum jelly as Rod Wax. But just to satisfy all
the doubting minds, and in the interest of explicitness this should cover all the bases:
http://www.damninteresting.com/story-of-vaseline/
Denny G
Denny G
Sandwich, IL
55shaker #934171 04/09/2013 1:18 AM
My apologies for having my mind in the proverbial gutter...it was to coincidental to resist. I think Mr. Graham is feeding us a line of bull-dungo on the 'vas-moline' story.
The man from Sandwich is way too devious for me, but he means well. smile
Stuart
55shaker #934208 04/09/2013 8:29 AM
Now Stu, I wouldn't pull your Jeeber, it's all fact.
And don't 'cha go mistakin' what yer Jeeber is either.
But....I hope Brian got his points to sparking after all this BS'n.
Denny G
Somewhere north of Sandwich, IL
Denny G
Sandwich, IL
55shaker #934309 04/09/2013 3:42 PM
would rod wax work on a johnson rod
Redryder pix
My Hotrod
55shaker #934319 04/09/2013 4:30 PM
might help with muffler bearings too
