| | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93267 10/25/2005 2:02 AM | Joined: Sep 2005 Posts: 67 Member | | Member Joined: Sep 2005 Posts: 67 | I noticed coming in a bit ago I was getting a flicker in my dash and headlights that appeared like it was something induced by the ignition....
when I revved the engine it smoothed out and got more pronounced when it idled back down...
any suggestions? a strategically placed capacitor maybe? a failing diode or rectifier? voltage regulator?
TIA | | |
#93268 11/02/2005 7:11 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Regulator ... I would think.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#93269 11/02/2005 10:58 PM | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | I agree with Alan. What you describe are the classic symptoms of a failing voltage regulator. Well, that is, if I presume your vehicle has the standard generator/voltage regulator setup.
Richard 58 3104
#93270 11/02/2005 11:37 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Is this a new problem...wasn't this solved in the Engine forum last week?
Stuart. | | |
#93271 11/03/2005 12:25 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I think he double posted and it was solved. He should have deleted this post. | | |
