0 members (),
83
Mod | | | Forums66 Topics128,081 Posts1,056,318 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Hello to All, I have a '46/47 Suburban project and need a bell housing to fit the newer 235 engine I put in to replace the 216. I did not save my old bell housing to mate up between my 3spd tranny and a '58 235. Which one will work and where to look? Did not see one in swap area. All help is greatly appreciated.
Patrick
Richard J Patrick - 1946 Suburban
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Patrick, 1938-1947 is one part number. And, 48-53 is a different part number. This may have to do with the engine bolts and/or the transmission bolts (or, maybe even another difference). Wait to hear from someone who knows. There is no question that you cannot use a 1954 and newer clutch housing, because the rear motor mount changed in 1954. What year 3-speed transmission do you have? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The one you need 46/47 and earlier, has a smaller tranny pattern plus bosses (3 threaded holes) to mount your master cyl and pedal bracket. Should not be difficult to find. Also these early ones bolt up to all 216, 235 and 261s.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As Tim said, you need a 1938-46 truck bellhousing. This will bolt to the 235 and your 46/47 trans.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Holy Schmoly, A lot of very quick replies. My tranny is a stock 46/47 I believe. So as you all say , now I need to find a housing from a 38-46.
Thanks tons!
Patrick
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | A gmc bellhousing from 1939-1946 will also work. | | |
