| | | Forums66 Topics128,153 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93170 10/16/2005 6:00 PM | Joined: Oct 2005 Posts: 10 Junior Member | | Junior Member Joined: Oct 2005 Posts: 10 | I am working on a 72 chevy truck and the turn signals work fine until you turn the head lights on, then the right side does not blink I also have the same problem with a chevy motorhome. :confused: | | |
#93171 10/16/2005 7:36 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | It is most likely a poor ground on the right front or right rear lamp assembly, especially if the parking/tailights share those assemblies. | | |
#93172 10/16/2005 7:59 PM | Joined: Oct 2005 Posts: 10 Junior Member | | Junior Member Joined: Oct 2005 Posts: 10 | Thanks for the reply I'll check it out.  | | |
#93173 10/17/2005 12:29 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | One of the bulbs is bad, the turn element is shorted to the tail or park element... that happens...when you turn on the headlights then it lights the turn element, i bet if you check the turn lights with the headlights on...either the front or rear one is brighter than park or tail... and it will be that bulb.....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#93174 10/17/2005 1:45 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I concur with (Weightcallenged)Weed, Scott | | |
#93175 10/17/2005 5:26 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | But you would both be wrong. With that scenario all of the parking lights and tail lights would flash when the lights weren't on when the right turn signal was enabled. Sometimes just changing the bulb will clean up the ground in that socket however. | | |
