4 members (Brian Moore, HandyAndy, Bill Hanlon, 2-Ton), 147 guests, and 2 robots.
Topics128,060
Posts1,055,836
Members48,427
#93103 10/11/2005 8:26 PM
I'm converting to 12v with my engine swap (47 AD) what's the easiest way to add turn signals? I've seen the little switch I think in Chevy Duty, but it looks dumb. Any other suggestions?
jay
Your lack of preparation is not my emergency
#93104 10/11/2005 10:29 PM
V
V Offline
I agree. I have the chrome add-on turn signel switch that mounts on the steering wheel shaft. I wish there were a cleaner mount avalable.
#93105 10/12/2005 1:01 AM
I'm no electrician, but how easy would it be to build one from parts and put a small switch on the dash, similar to one that's already there?
jay
#93106 10/12/2005 1:13 AM
V
V Offline
You would seem to be onto something there. Maybe a simple threeway toggle switch under the dash that could be turned on (left or right) and manually turned back to off. No visable switch would improve my truck's look and return it to the original stock appearance.
Anybody build one?
#93107 10/12/2005 1:39 AM
Why couldn't you mount the column mounted switch behind the dash, after removing it from the column, with the lever pointing down and just visible? Push it to the left for a left turn and to the right for a right turn. You could shorten the lever.
#93108 10/12/2005 1:53 AM
V
V Offline
I'll look at it and see if that is possible.
#93109 10/12/2005 2:36 PM
It wouldn't be too difficult to make a turn signal switch out of parts from radio shack.
You'd need a flasher (of the appropriate voltage) to make it work, though. Pretty small potatoes, though.
Personally, I just left the lever there that someone put on there back in the day. It doesn't look too bad, and it's not chrome.
Although, you could just stick your arm out of the window and signal that way... grin
#93110 10/12/2005 5:57 PM
i have the switch under the dash, i got it at autozone. the only drawback is i leave it on sometimes for blocks after a turn. you should put a light in the system. the turn signal under the dash with lever pointing down sounds interesting. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#93111 10/12/2005 6:42 PM
I have a new one,,, works well, the old hand-signals grin
Redryder pix
My Hotrod
