Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (carbking, baldeagle, Ridgeback, 3B), 37 guests, and 0 robots.
Topics128,005
Posts1,055,253
Members48,418
#931046 03/27/2013 8:33 PM
Yesterday, the Powerglide transmission in my 1966 C-10 did not engage in the PARK position, and rolled into a ditch. Fortunately, the truck sustained no damage, but it nearly hit a utility pole.
It has not engaged in PARK a few times before, but it has happened infrequently.
Is this likely to be a linkage problem, or is it the parking pawl assembly?
Either the detent is flawed/worn or the shifter down-rod may be out of adjustment. With the keeper on the shifter down-rod loosened, put the transmission pivot and the shift indicator in P. If it holds in P, tighten the shifter down-rod keeper. If not, be sure the pivot assembly is not turning, independent of the pivot shaft, going into the transmission housing.
