0 members (),
136
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 56 | Quiet awhile back I posted casting and serial number information for my 216, but wasn't able to solve my identification issue, which still bugs me now. I have a 1950 Chevy 3100 1/2 ton with a 216. The 216 is not the original. In researching the engine I determined that the block & head casting numbers are 3835849 & 3835517, which identifies the engine as a 52/53 216. Now for the strange part. The engine has the serial number DR140622CAL, the date code on the block says CON4 G167 and the engine has main and rod insert bearings, which could have came from a bearing/rod conversion kit that was once available, or the rods were converted. Is it possible that this might be a replacement engine rather thsn a rebuild? Is there any casting or serial info for replacement engines? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The main bearings have always been inserts. The rods must have been converted in the past to inserts. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Same poster there as here.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It would not be uncommon to have a truck in which the block had been replaced with a new one from the factory. Could have burned it up from heavy use or abuse, cracked the block by not keeping antifreeze in it. It would have been delivered without a SN and the installer would have been expected to transfer the SN from the original engine to the new short block or fitted block.
Denny G
Denny G Sandwich, IL
