0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
Quiet awhile back I posted casting and serial number information for my 216, but wasn't able to solve my identification issue, which still bugs me now. I have a 1950 Chevy 3100 1/2 ton with a 216. The 216 is not the original. In researching the engine I determined that the block & head casting numbers are 3835849 & 3835517, which identifies the engine as a 52/53 216. Now for the strange part. The engine has the serial number DR140622CAL, the date code on the block says CON4 G167 and the engine has main and rod insert bearings, which could have came from a bearing/rod conversion kit that was once available, or the rods were converted. Is it possible that this might be a replacement engine rather thsn a rebuild? Is there any casting or serial info for replacement engines?
The main bearings have always been inserts. The rods must have been converted in the past to inserts.
DR140622CAL
The "CAL" might indicate that it was a replacement engine in California?
added/edited later
Found this response that was posted in 2002 from Gene, Chev Nut - he is a true expert.
Ex Hall Monitor
Ex Hall Monitor
Same poster there as here.
It would not be uncommon to have a truck in which the block had
been replaced with a new one from the factory. Could have
burned it up from heavy use or abuse, cracked the block by not
keeping antifreeze in it. It would have been delivered without
a SN and the installer would have been expected to transfer the
SN from the original engine to the new short block or fitted block.
Denny G
Denny G
Sandwich, IL
