5 members (Oswald, FAST55, Bill Hanlon, 2 invisible), 85 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
#9306 03/31/2005 12:10 PM
Junior Member
Junior Member
I need to change the oil in my '64 C10 - fitted with a 230cu inline six.
Can anyone tell me how much oil I'll need (including filling a new filter) as I don;t have a workshop manual?
Many thanks, Limey
#9307 03/31/2005 3:48 PM
As I remember it, it should be 4 U.S. quarts. I usually fill the crankcase one quart short, run the engine to fill the oil filter, then check the level and add oil until it reaches the "full" mark on the dipstick. It's lots simpler to add a little, than to try to remove oil from an overfilled crankcase!
#9308 04/01/2005 2:06 AM
Put 5 quarts in, if it's too full, it will leak out or burn down to the correct level(joking),
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#9309 04/01/2005 10:59 AM
Junior Member
Junior Member
OK thanks guys - that's about 4.5 litres for us Europeans who are forced to work in metric!
Limey
