2 members (klhansen, 1 invisible),
107
Mod | | | Forums66 Topics128,119 Posts1,056,648 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I have rebuilt two Carter W-1 684s carbs for my 235 with dual carbs and have it running very smooth at idle. Have not taken it on the road yet and am trying, with no luck, to find the correct metering rod gauge for this carb to make sure they are set right. Does anyone know a source for these gauges. From what I have researched I need a T109-25. Thanks for any help.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Check with Jon, aka Carbking, he has a good inventory of Carter parts and tools. He should be able to supply you with a gauge. http://www.thecarburetorshop.com/ Denny G
Denny G Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I found someone that handles vintage tools. He said that he has a few 25s in his for sale items. I should have one shortly. Thanks for the help.
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Any update on the adjusting tool or how it runs?
I have two ready to install on my 250. Joe | | |
