| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#9306 03/31/2005 12:10 PM | Joined: Jan 2005 Posts: 48 Junior Member | | Junior Member Joined: Jan 2005 Posts: 48 | I need to change the oil in my '64 C10 - fitted with a 230cu inline six.
Can anyone tell me how much oil I'll need (including filling a new filter) as I don;t have a workshop manual? Many thanks, Limey | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | As I remember it, it should be 4 U.S. quarts. I usually fill the crankcase one quart short, run the engine to fill the oil filter, then check the level and add oil until it reaches the "full" mark on the dipstick. It's lots simpler to add a little, than to try to remove oil from an overfilled crankcase! Jerry
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Put 5 quarts in, if it's too full, it will leak out or burn down to the correct level(joking), Scott | | |
#9309 04/01/2005 10:59 AM | Joined: Jan 2005 Posts: 48 Junior Member | | Junior Member Joined: Jan 2005 Posts: 48 | OK thanks guys - that's about 4.5 litres for us Europeans who are forced to work in metric! Limey | | |
