4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#928019 03/16/2013 7:13 PM
I am putting a new hei distributor on my truck. It is a '59 Apache that I recently put a '67 250 motor out of a Chevy II in. I have the distributor and wires ready to install and was just wondering about the sparkplugs. Did they use different plugs when they went to hei or did they gap them different? I have good plugs in it now and was hoping to just regap them.
Thanks a lot,
Gene
Gene
1959 Apache
I've always read to gap them wider. That's what the instructions with my Street Fire unit said to do.
Riding in the Passing Lane
Set the gaps at .045.
1972 Chevy c10 Cheyenne Super
That is just what I needed.
Thanks a lot!
Gene
Gene
1959 Apache
When the HEIs came out in '74/'75 GM recommended .060. After a year they changed that to .045 where it stayed for the "High Energy" systems. Also, the first ones used an external coil and different cap. The large diameter was to prevent crossfiring between plugs. Be sure to run a new switched 12ga or larger wire from the switch.
Best wishes,
Les
