1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I am putting a new hei distributor on my truck. It is a '59 Apache that I recently put a '67 250 motor out of a Chevy II in. I have the distributor and wires ready to install and was just wondering about the sparkplugs. Did they use different plugs when they went to hei or did they gap them different? I have good plugs in it now and was hoping to just regap them. Thanks a lot, Gene
Gene 1959 Apache
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've always read to gap them wider. That's what the instructions with my Street Fire unit said to do. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | That is just what I needed. Thanks a lot! Gene
Gene 1959 Apache
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | When the HEIs came out in '74/'75 GM recommended .060. After a year they changed that to .045 where it stayed for the "High Energy" systems. Also, the first ones used an external coil and different cap. The large diameter was to prevent crossfiring between plugs. Be sure to run a new switched 12ga or larger wire from the switch.
Best wishes,
Les | | |
