Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, CuzzFuzz), 27 guests, and 0 robots.
Topics128,003
Posts1,055,245
Members48,418
#930279 03/24/2013 11:11 PM
I adjusted the shifter to the specs and the truck doesn't want to go into 2nd. I can go from 1st to 3rd but not 3rd to second. The bracket that comes off the steering column to linkage that ends at the tranny doesn't get into the right position and therefore not allowing it to get into 2nd gear. I tried looking for bushings but can't seem to find anything to make it more sturdy. Has anyone had this issue or any advice? Thanks. This is the only thing holding up my truck from driving it on the street. I have a 53 chevy truck with 3 on the tree.
berts53 #930289 03/24/2013 11:51 PM
are you sure you have the right rods on the levers at the shift box? the bushings there and at the trans levers can be faked using the bronze door hinge bushings from the HELP rack [#38374] at the auto parts stores
Flxible #930301 03/25/2013 1:03 AM
I believe I have the correct rods. I am using the same rods that came with the truck and engine. There is a lot of slop on the bracket that is closest to the firewall and I'm thinking that is the issue. when it doesn't want to go into 2nd I move the bracket on the rod a little and then it will go into gear but then a couple times after shifting a couple times it doesn't want to go into 2nd again. I really am bewildered at what to do.
berts53 #930344 03/25/2013 8:31 AM
closest to the firewall is the 1st/reverse lever - have you opened the box on the column and checked for wear on the forks and pawl inside? usually problems like that are misalignment in the box, could be the spring inside [next half dozen pics in that album apply too]
