7 members (55shaker, dt235sd, Hanks custodian, NJC, 3B, Gdads51, 1 invisible),
211
Mod | | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Hi, I have a '42 1/2 ton and I am trying to match a rearend to a rebuilt 235 (3/4 cam and 2 two barrels) and Saginaw 4peed. Current recommendation is a rearend from a 78-88 Cutlass, Monte Carlo or Grand prix. Appreciate any advice/recommendations relative to ride, reliability and ease of replacement. Thanks | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If it was my truck I would get a S-10 rear end with a 3:73 gear ratio in it. | | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I thought the s-10 might not be wide enough. What years should I look for? Thanks | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | In order to provide a great recommendation, we need to know what you want the truck to do that it is not capable of doing with what you currently have.
Are you looking for a highway cruiser? A rock puller? A wall climber?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | i just want a reliable highway cruiser | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | I am using a rear axle out of a 2002 4wd Blazer. Same Wheel Mounting Surface to Wheel Mounting Surface as the stock rear end. It comes with disc brakes and a 3:42 ratio. | | |
