| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 16 New Guy | | New Guy Joined: Nov 2012 Posts: 16 | who makes the side windows (sliders) and rear barn door windows (glass) for 1951 burb | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Jim Carter sells the patterns and you have your glass man cut them from flat glass. Window Glass Pattern 1947-Early 1955 Suburban Item Number: WI250 Retail: $9.95 SET I am not sure that the barn door glass can be purchased new, put an ad in the swap meet section for good used glass. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | George, I may be wrong, but I think the rear windows are now offered by someone. I'll need to do some research but I think so. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Alvin, I also thought they were/are available, but I have checked the likely sellers/suspects and cannot find them. Oops, I checked Chevs of the 40s while writing this post). They have 47-55 Suburban side glass and panel-door rear glass. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....at $139 each no wonder I forgot who had them. Ouch...but if ya aint' got any I guess you have to pay! But then again, I've always known they are proud of their products. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Jim carter has the rear barn door glass $165 pair.
Tim
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | I had a rear sliding window for my 58 Burb made at a local glass shop. I had the old one that was cracked in half to use as a pattern. It was made from "2 ply" safety glass. Cost me $65. It was a bit more than I expected but not too pricey. I'll eventually have to replace all the side glass as it is really showing it's age.
Just making the point that you can have glass fabricated if you have a useable pattern.
Larry
