4 members (Bill Hanlon, dt235sd, Gray_Ghost, blanch53), 367 guests, and 4 robots.
Topics128,087
Posts1,056,115
Members48,435
#930081 03/24/2013 11:46 AM
Hi,
I have a '42 1/2 ton and I am trying to match a rearend to a rebuilt 235 (3/4 cam and 2 two barrels) and Saginaw 4peed. Current recommendation is a rearend from a 78-88 Cutlass, Monte Carlo or Grand prix. Appreciate any advice/recommendations relative to ride, reliability and ease of replacement. Thanks
If it was my truck I would get a S-10 rear end with a 3:73 gear ratio in it.
I thought the s-10 might not be wide enough. What years should I look for? Thanks
ODSS Lawman
ODSS Lawman
In order to provide a great recommendation, we need to know what you want the truck to do that it is not capable of doing with what you currently have.
Are you looking for a highway cruiser? A rock puller? A wall climber?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
i just want a reliable highway cruiser
I am using a rear axle out of a 2002 4wd Blazer. Same Wheel Mounting Surface to Wheel Mounting Surface as the stock rear end. It comes with disc brakes and a 3:42 ratio.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
