4 members (Greg_H, WICruiser, Chooglin, 1 invisible), 66 guests, and 2 robots.
Topics128,151
Posts1,057,004
Members48,460
My left ankle gives me fits sometimes after twisting it many years ago and in the future might have to go with a automatic trans,I know adapters are used to put a modern automatic behind a 235 but is the adapter made for a original type starter or a modern version. I just put the foot stomp back on it and if I were to ever go with a automatic I would want to keep it if possible,anybody know if its doable.
any automatic has a built in bellhouse, which won't have the mounts for the linkage, and any starter that would work with the flex plate will have a key start solenoid, so you'd hafta rig your own, which would be a push switch on or under the floor with the pedal button attached
Here's what I came up with to have a foot starter with my 250/200-4R in my 57 3100. I used a foot starter switch for a tractor (Tractor Supply #0236643} . It will bolt to the floor and fit through the hole for the stock linkage. I built an adapter to allow me to attach the stock foot pedal to the switch.
Here's a pic of the parts .
And a pic of it assembled .
After installing the rubber boot over it, it should look nearly stock.
Comments welcomed.
regards,
Leon
Nice work Leon. Seems like a perfect reply.
This belongs in the tech-tips section also.
Thanks Leon !
I'm going to use that setup in my 292/NV4500 project.
1954 4400
1954 3800
Jim D.
'41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck
'54 Chevy 3800 Dump........New Truck!
'54 Chevy 4400 flatbed/dump, Gone to my brother-in-law
'13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles
'01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
