1 members (klhansen),
90
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | My left ankle gives me fits sometimes after twisting it many years ago and in the future might have to go with a automatic trans,I know adapters are used to put a modern automatic behind a 235 but is the adapter made for a original type starter or a modern version. I just put the foot stomp back on it and if I were to ever go with a automatic I would want to keep it if possible,anybody know if its doable. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any automatic has a built in bellhouse, which won't have the mounts for the linkage, and any starter that would work with the flex plate will have a key start solenoid, so you'd hafta rig your own, which would be a push switch on or under the floor with the pedal button attached
Bill | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Here's what I came up with to have a foot starter with my 250/200-4R in my 57 3100. I used a foot starter switch for a tractor (Tractor Supply #0236643} . It will bolt to the floor and fit through the hole for the stock linkage. I built an adapter to allow me to attach the stock foot pedal to the switch. Here's a pic of the parts . And a pic of it assembled . After installing the rubber boot over it, it should look nearly stock. Comments welcomed. regards, Leon | | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | Nice work Leon. Seems like a perfect reply. This belongs in the tech-tips section also. | | | | | Joined: Feb 2000 Posts: 120 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 120 | Thanks Leon !
I'm going to use that setup in my 292/NV4500 project. 1954 44001954 3800Jim D. '41 Chevy 1-Ton Pickup/dump...292" 4-speed w/Ranger OD ... Newest Truck '54 Chevy 3800 Dump........New Truck! '54 Chevy 4400 flatbed/dump, Gone to my brother-in-law '13 GMC 1500 daily driver ... 5.3 6-speed auto just turned 13k miles '01 Chevy 2500hd, might be my new daily driver ... 6.0 / 4L80-E
