| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I realize that a lot of folks have done this swap. I have just one quick question. I've been told it's a rather straightforward job and only 2 holes need to be elongated for the new crossmember to go in. Are the holes in the crossmember or in the existing frame rails? Which 2 are they. Any help would be appreciated as I've already got new ball joints, A-arm bushings, and tie rod ends installed and ready to go with this. Thanks Tramp | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | For the benefit of myself and maybe a few others, what are you talking about? I know what a cross member is, I know what swap is, but which one and where and why do a lot of folks do this?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Sorry if I didn't make myself more clear. I'm taking the front crossmember from an 81' model 1/2 ton with power steering and disc brakes and transplanting it into the 64'. Gain newer technology, better braking and handling. Makes me feel more secure in driving the 64' as I built it to drive and not wait for the perfect weather to get it out of the garage as a museum piece. Tramp | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
