Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#929924 03/23/2013 6:25 PM
It looks like I am missing some kind of spacer for the front engine mount.The rear transmion mount and bell housing mounts will not let the engine down in the front to sit on the mount,I put some pics in my link to look at.Does anyone know what I need?
3B Offline
Hy metal shaper, there is nothing missing that I'm aware of. I've never seen any hangup problems with this type of engine mounting. In your pictures it shows the transmission with the stubshaft mounted, is the ball collar loose enough to allow the stubshaft to move around a bit? Hope that helps.
There are spacer/thick washers that go between the mount and crossmember. That is what the wear patterns on the mount and crossmember are from.
Denny has pics of this I'm sure he will post.
My Blog
I have a post in this area, close to your's, which is for my 50 3100. there's also a link in the post that DADS50 posted concerning the front engine mount. Don't know if I can post the link, but here it is. Hope this helps.
www.pbase.com/dennygraham/1950_motor_mounts&page=all
Thanks,The pics and info is a help.I saw the wear marks but didn't know what went there.
- Lonnie
My '54 3104
What size is your truck?
Your rear mount look thicker than those on my 1/2 ton
...click...
!946,Chevy 3/4 ton
Thanks to some of the board members here I found the problem.I did not know the tail shaft that bolts to the back of the transmission would move by loosening the 4 bolts that fasten it to the transmission,The 4 bolts were tight enough to hold the weight of the engine from rotating down and sit on the front mount.I guess the real problem was i was slow on the draw .It took a while for what I was being told to sink in.Thanks to every one.
Frame looks nice what paint was used?
Singal stage urethane by ppg
It sounds like you need to add a gasket or more to the ball retainer.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
