2 members (Gray_Ghost, Joe W),
211
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 19 New Guy | | New Guy Joined: Mar 2013 Posts: 19 | I am now in the mid stream of refinishing the gauge's. I drilled out the aluminum rivet the holds the face plate to the gauge works with 5/64" drill bit. I will redrill the holes with a #44 drill and use #2 machine screw and nut to reassemble. With my thick farmer fingers, this is tweezer work.
The pointer or needle is painted some off-white color, it seams to have a green tint. Did these original needles glow or luminous in the dark? What color or paint have you used? All opinions on this issue will be appreciated.
Woodie | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Doubt they were luminous...supposed to be lighted by small bulbs in the back.. Mine, however, don't even have the bulb fixtures. In both the gauge cluster and spedo I think there were five bulbs in all... | | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | In my 55 series 2 the needles were all a light green color like the glow in the dark stuff...although they dont glow. I'm a VW restoration shop and simply used some 1966 VW bahama blue (which really isnt blue) that I had in stock. It was almost perfect. If I wouldnt have had the paint Id have just picked up some rustoleum fusion or krylon in a similar color.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I don't know what year your truck is, but my needles are white. I just used some white-out, easier than spray painting. | | | | | Joined: Mar 2013 Posts: 19 New Guy | | New Guy Joined: Mar 2013 Posts: 19 | '51, 3100 AD, I always forget. White out, sounds easier when a rattle can.
Woodie | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....and I use Appliance White | | |
